I'm not sure how it is supported for OtherEquipment but not Electric equipment. In both cases there is an equipment definition that is not associated with a schedule. When you make a load instance, in a space or a space type, you can associated the definition with a schedule, and a multiplier. While Ruleset Schedules are typically used, as shown on the screenshot below Fixed Interval Schedules are also supported. For any schedule type for this use case make sure values are fractional values (between 1 and 0). You might have to pre-process your data to support this, and then set the capacity of the definition to match.
