Compare the inputs that the OS app and PAT are providing to the measure, I think you will find them to have different behavior as to how they default input values. I would specifically check that PAT isn't setting 0 for optional inputs where the OS app is leaving them blank. If you ensure that the PAT inputs perfectly match the OS app, you will get the same result.
