Hello Wenyi,
probaply you already solved your problem. Sometimes the floor can also be hidden in the datConPar as in Buildings.ThermalZones.Detailed.Examples.MixedAirFreeResponse.
If you check all datCon... strings, you'll probaply could figure out the different surface areas.
I also started with the room models in Buildings recently. I figuered out a lot of the structure of the model, but I'm not able to connect the model Buildings.ThermalZones.Detailed.MixedAir with a second room model MixedAir, like in Buildings.ThermalZones.Detailed.FLEXLAB.Rooms.Examples.X3BWithRadiantFloor.
My approach till now: I opened Buildings.ThermalZones.Detailed.Examples.MixedAirFreeResponse and duplicated the Mixed Air model. I concted the 2. room with the obligatory parameters weaBus and qGain, I adjusted the romms to the meassurements of my building and exchanged the conecting wall between the rooms with an indoor wall. Till now simulation is working fine. Now I activated the ports conBou in room1 and conSur in room2 and shifted the connecting wall to SurBou in room2 and to datConBou, wich seemed to be locical. But this is causing an Error
Do you have experience in connecting mutiple rooms amongst each other?
