It's important to point out that there are two schedules that work together for lighting:
- The lighting operation schedule input for
Lighting
objects that determines the fractional use of electricity for lights. This fractional schedule assumes that there are no daylighting controls. - The availability schedule input for
Daylighting:Controls
object that determines when the daylighting controls is available to turn off or reduce the electric lighting, overriding the lighting operation schedule (input parameter above). This is availability -- the daylighting controls won't override normal operation all the time, just if enough daylight illuminance reaches the daylight sensor's position.
So, if you don't need electric lighting after 6pm, that would be reflected in the lighting operation schedule -- schedule values of 0 after 6pm. This can be edited in the Schedules tab (second from the top) in the OpenStudio application.
You can read the OpenStudio Plugin for SketchUp Guide section on adding new daylighting controls for more information. From following this guide in my own testing, the daylighting controls availability schedule input is not exposed in the OpenStudio application or SketchUp plugin. If the space containing a daylight sensor (aka reference point) is assigned to a thermal zone, and the thermal zone has a primary daylight controls, then this is what the EnergyPlus Daylighting:Controls
object looks like.
Daylighting:Controls,
Thermal Zone 1 DaylightingControls, !- Name
Thermal Zone 1, !- Zone Name
, !- Daylighting Method
, !- Availability Schedule Name
Continuous, !- Lighting Control Type
, !- Minimum Input Power Fraction for Cont ...
, !- Minimum Light Output Fraction for Cont ...
, !- Number of Stepped Control Steps
, !- Probability Lighting will be Reset When ...
Daylighting Control 1, !- Glare Calculation Daylighting Ref ...
0, !- Glare Calculation Azimuth Angle of View ...
, !- Maximum Allowable Discomfort Glare Index
, !- DElight Gridding Resolution {m2}
Daylighting Control 1, !- Daylighting Reference Point Name 1
1, !- Fraction of Zone Controlled by Reference ...
500; !- Illuminance Setpoint at Reference Point ...
Note that the availability schedule name input is blank, which default to "always on" (constant value of 1). This is common practice for annual simulations, but design days usually have daylight controls turned off to yield higher heating/cooling capacities and helps avoid unmet heating/cooling hours during annual simulations.
Lighting
You can read the OpenStudio Plugin for SketchUp Guide section on adding new daylighting controls for more information. From following this guide in my own testing, the daylighting controls It's common practice to keep the availability schedule input is not exposed in the OpenStudio application or SketchUp plugin. If the space containing a daylight sensor (aka reference point) is assigned to a thermal zone, and the thermal zone has a primary daylight controls, then this is what the EnergyPlus Daylighting:Controls
object looks like.
Note that the availability schedule name input is blank, which default to "always on" of daylighting controls on always (constant value of 1). This is common practice for annual simulations, but 1) EXCEPT for design days usually have daylight controls turned off to yield days, since removing daylighting controls yields higher heating/cooling capacities and helps avoid unmet heating/cooling hours during annual simulations.
