What I have been doing with OpenStudio is I created a script to import either a ZoneVentilation:DesignFlowRate or ZoneVentilation:WindandStackOpenArea object with arguments for the thermal zone, schedule, etc. for any inputs I want as variables. You could create this script using the Measure Writing Guide for EnergyPlus measures or copy one from the BCL and modify to fit your measure needs. There is also a AvailabilityManager:HybridVentilation object I have not tried yet but may be worth looking into as well to import as a measure.
What I have been doing with OpenStudio is I created a script to import either a ZoneVentilation:DesignFlowRate or ZoneVentilation:WindandStackOpenArea object with arguments for the thermal zone, schedule, etc. for any inputs I want as variables. You could create this script using the Measure Writing Guide Guide (http://nrel.github.io/OpenStudio-user-documentation/measures/measure_writing_guide/) for EnergyPlus measures or copy one from the BCL and modify to fit your measure needs. There is also a AvailabilityManager:HybridVentilation object I have not tried yet but may be worth looking into as well to import as a measure.
