If you're autosizing the coil parameters, check your EIO file to check the capacity of your cooling coils.
If the capacity of your cooling coil is = 0, then you either have a problem with your zone loads (actual loads like people/lighting and thermostat design temps) or with your sizing parameters (Sizing:Zone/Sizing:System).
If the capacity of your cooling coil is > 0, then you have some sort of operational problem. Is your AHU making setpoint, or is it just blowing hot air because the cooling coil is not coming on?
