Someone else may know the direct answer to your question, but an alternative option could be to set up an EMS script that turns on an (electric)Exterior:FuelEquipment object, with a capacity of your fan at its lowest speed, anytime the FPFC fan turns off. Or if the fan was a considerable size and you wanted that heat to go into a certain zone you could instead use an OtherEquipment object.
