I would try searching for an energymanagementsystem:Sensor object, since that’s what is directly referenced in the error.
One thing to keep in mind is that the ideal air loads measure deletes zone equipment when it runs. So it may be that some stuff is getting stranded when that happens depending on what you have in the model. You may need to do some preemptive house cleaning to get an ideal air load run.
