Yes and no. No, because eQUEST will only let you load INP of PD2 files. Yes, because you should be able to convert your BDL file to an INP file by removing all non-valid INP fields (and changing the extension from .BDL to .inp). For example:
* 586 *
* 587 * "South Win (G.S1.E1.W2)" = WINDOW
* 588 * GLASS-TYPE = "Window Type #2 GT"
* 589 * X = 60.7483
* 590 * Y = 3.10833
* 591 * HEIGHT = 5.00333
* 592 * WIDTH = 46.4456
* 593 * FRAME-WIDTH = 0.108333
* 594 * FRAME-CONDUCT = 2.781
* 595 * ..
Should be changed to
X = 60.7483
Y = 3.10833
HEIGHT = 5.00333
WIDTH = 46.4456
Tedious manually, much easier with a script or using regular expressions.
* 586 *
* 589 * X = 60.7483
* 590 * Y = 3.10833
* 595 * ..
X = 60.7483
Y = 3.10833
HEIGHT = 5.00333
WIDTH = 46.4456
Tedious manually, much easier with a script or using regular expressions.script.
Yes and no. No, because eQUEST will only let you load INP of PD2 files. Yes, because you should be able to convert your BDL file to an INP file by removing all non-valid INP fields (and changing the extension from fields. For example:.BDL to .inp).
* 586 *
* 589 * X = 60.7483
* 590 * Y = 3.10833
* 595 * ..
X = 60.7483
Y = 3.10833
HEIGHT = 5.00333
WIDTH = 46.4456
Tedious manually, much easier with a script.
