You need to add a specific reporting measure in order to view the Openstudio results. You can download the measure from OpenStudio Application by going to Components & Measures > Find Measures > then search for "OpenStudio Results" under Reporting category. Add this measure in the "Measures" tab by dragging it from the library to the reporting measures sections. You should be able to see the graphical presentation of the results after running the simulation.
The image you are attaching shows ResultsViewer which has been replaced with Data Viewer (DView) in the newer OpenStudio versions. According to the most recent release notes: "Note that PAT and DView are not included in either the SDK or Application installers. You will need to install PAT separately which is distributed on the OpenStudio-PAT GitHub page and DView at the Dview home page."
Some users reported difficulties in using DView and preferred to use timestep which is another EnergyPlus timeseries visualization tool.
