I faced the exact same problem. I solved it by inputting not only Chilled Water Inlet Node Name
and Chilled Water Outlet Node Name
, but also Condenser Inlet Node Name
and Condenser Outlet Node Name
. Any Node name is fine, but blank is not acceptable for these four fields.
