The availability manager for your HHW plant is specified in the Plantloop object. You can modify the availability managers to turn off the entire plant (including pumps). Alternatively, you can modify the availability managers controlling the airside systems, as I suspect this summer cycling is caused by airside equipment calling for heating during that period.
