Site Ground Temperature is not used by my models to calculate ground heat transfer. This is because my models use Foundation Kiva instead of some other algorithm. If I look at the wall/floor surface boundary conditions, they are "Foundation," and the boundary condition object is a Foundation Kiva object.
Instead of playing with Kiva settings to try to minimize ground heat transfer, I am instead adapting a measure to change the boundary condition for surfaces with "Foundation" boundary conditions to "Adiabatic."
This should hopefully result in zero conduction between the building and the ground.
Site Ground Temperature Based on what I can tell, there is not used by no heat transfer in any of my ResStock models from the ground. I changed the ground temperature from 18 deg C to calculate ground heat transfer. This is because 100 deg C and noticed very little change in any of my models use Foundation Kiva instead of some other algorithm. If zone temperature variables. I look looked at the wall/floor surface boundary conditions, they are "Foundation," crawl zone, living zone, unfinished attic zone, and the boundary condition object is a Foundation Kiva object.garage zone.
