Sorry you are having problems with the copy on BCL, I did just test the GitHub copy and that appears to work and can be found here https://github.com/NREL/openstudio-common-measures-gem/tree/develop/lib/measures/air_wall_zone_mixing
Here is screenshot image description
You could also consider the new Air Boundary Construction object in OpenStudio, which supports new EnergyPlus air wall capability. That is shown below. image description
I did just get it updated on BCL so it should match GitHub. So you can try to update your local BCL copy instead of using GitHub.
