I don't think this gives enough information to understand why the simulation is not working, so I'll respond with some generic comments:
Have you reviewed the output to confirm that the fan turns on when needed? and is controlling to the proper setpoint? with full outdoor air?
Normally you can "reverse engineer" the input problem by noting which part of the operation is not doing as you expect.
