@luca, I was able to replace the same issue you saw with the copy that was on BCL, but not the most current development copy on our public GitHub repository for common measures. I just the updated BCL copy, so you should see an update to your locally copy. If you don't. you can try to throw away our BCL directory or you can use the link above to the GitHub repository if you are comfortable with that.
To summary approaches
1. Just Quit and Restart the OpenStudio Application and it should find new version of measure. You can look under your user account in BCL directory for last modified date to confirm, or just try and run the simulation.
2. If it doesn't find the new copy try to throw away the BCL directory under your user account
3. If you are comfortable you can checkout or get a zip file of github.com/NREL/openstudio-common-measures-gem, and then set it on your computer to my measures directory. Just make sure you drag over the copy with "my" instead of "bcl" into your workflow.
