1st step is to create a chilled water loop. Make sure you click on the dotted line and choose the appropriate loop type as well as the rest of the settings
2nd step is to create a hot water loop. Same story here, click on the dotted line and select all the appropriate settings
3rd step is to go to the thermal zones tab. Drag and drop a four pipe coil object of your choosing from library to the Zone Equipment and then click on it. You will see two chain like icons on the top right of you screen, click each one and connect the OS:Coil:Heating:Water with your hot water loop and the OS:Coil:Cooling:Coil with your chilled water loop.
This way you can create a fan coil system. My suggestion would be though, to increase your knowledge in HVAC systems first and then try to model them.
