In TRNSYS 18, Cooling Tower component Type161 tries to control the leaving water temperature by modifying the flow on the air side. If you want to modulate the water flow you will need to apply a variable speed pump component and determine your own algorithm for modifying the flow rate to maintain the leaving temperature. I warn you that this is a very difficult control equation to figure out.
