Thermal and solar absorptances are only considered in EnergyPlus when appropriate. For instance when a material surface sees the outside environment, other interior surfaces, etc. Otherwise, those attributes are ignored at run time, as in the case of conductive heat flow between 2 materials. See: Input Output Reference. If uncertain, stick to the default values e.g., 0.9 (thermal) or 0.7 (solar).
Thermal and solar absorptances are only considered in EnergyPlus used when appropriate. For instance when a material surface sees the outside environment, other interior surfaces, etc. Otherwise, those attributes are appropriate - they're ignored at run time, as in the case of conductive heat flow between 2 materials. See: otherwise, see : Input Output Reference. If uncertain, stick to the default values e.g., 0.9 (thermal) or 0.7 (solar).
