SOLVED!
Okay. I Have solved the issue in the tair_sys by changing:
tair_sys, !- Name
NODE BLOCK1:ZONEWEST ZONE, !- Output:Variable or Output:Meter Index Key Name
System Node Temperature; !- Output:Variable or Output:Meter Name
in
tair_sys, !- Name
NODE BLOCK1:ZONEWEST IN, !- Output:Variable or Output:Meter Index Key Name
I can say more that in the 9.4 version the EMS actuators did take action if the zone load was zero and not in the 9.0 version. (https://github.com/NREL/EnergyPlus/issues/8579)
tnx
