Well, I guess I'll answer this myself, perhaps an unimaginative answer will inspire someone else to chime in with something slicker.
I ended up making a basic EMS program that takes hard coded surface areas for different modules of the RTU, then calculates and sums the UA dT (U-value also hard coded) for each module at each time step based on the applicable air temperature and puts the load into the zone begin served as "other equipment".
I use whether the fan is running or not to determine if losses are occurring.
I ended up making a basic EMS program that takes hard coded surface areas for different modules of the RTU, then calculates and sums the UA dT (U-value also hard coded) for each module at each time step based on the applicable air temperature and puts the load into the zone begin served as "other equipment". other equipment.
I ended up making a basic EMS program that takes hard coded surface areas for different modules of the RTU, then calculates and sums the UA dT (U-value also hard coded) for each module at each time step based on the applicable air temperature steps and puts the load into the zone begin served as other equipment.
