This is the % of the on-site thermal sources. So for each row i it's that row's Heat GJ / Total On-site Thermal Sources GJ.
$$Percentage = 100 \times \frac{HeatGJ_{i}}{\sum_{j=1}^{6}HeatGJ_{j}}$$
You can see the source code here in OutputReportTabular.cc#L8320-L8341
So logically in your case, since you have only one type of on-site thermal sources, it shows 100%.
: $$Percentage = 100 \times \frac{HeatGJ_{i}}{\sum_{j=1}^{6}HeatGJ_{j}}$$\frac{HeatGJ_{i}}{\sum_{j=1}^{7}HeatGJ_{j}}$$
