Shade controls in EnergyPlus should do what you want. Here it is demonstrated in the SketchUp Plugin, but it is also accessible in the OpenStudio Application. Go to the Spaces tab, then sub-surfaces, and then shading control.
Shade controls in EnergyPlus should do what you want. Here it is is demonstrated in the SketchUp Plugin, but it is also accessible in the OpenStudio Application. Go to the Spaces tab, then sub-surfaces, and then shading control.
