We upgrade the min_version on a measure when we know we are using new method or otherwise know a change will break it, but we can mis some incompatibilities since we don’t test older versions of OpenStudio against newer measures. We do release a version of measure gems for each major OpenStudio release. New measure gem repositories list a septic OS and E+ version, We didn’t do this for 2.9.1 but the 0.1.0 or 0.1.1 model articulation gem should provide you the best stability for 2.9.1. Let me know if measures from one of those releases doesn’t work. You can checkout the GitHub repo or install the gem. In either case you need to up date your MyMeasures directory to where this copy of the measure is on your computer. If you have a newer version of the measure in your BCL directory you may want to delete that to avoid any confusion as to witch measure is being used.
We upgrade the min_version on a measure when we know we are using new method or otherwise know a change will break it, but we can mis some incompatibilities since we don’t test older versions of OpenStudio against agains’t newer measures. We do release a version of measure gems for each major OpenStudio release. New measure gem repositories list a septic OS and E+ version, We didn’t do this for 2.9.1 but the 0.1.0 or 0.1.1 model articulation gem should provide you the best stability for 2.9.1. Let me know if measures from one of those releases doesn’t work. You can checkout the GitHub repo or install the gem. In either case you need to up date your MyMeasures directory to where this copy of the measure is on your computer. If you have a newer version of the measure in your BCL directory you may want to delete that to avoid any confusion as to witch measure is being used.2.9.1
