For EnergyPlus the SQL and tabular data (which includes the HTML) has to be selected as IS or IP. OpenStudio (specifically the OpenStudio Results measures) expects that to be in SI units which aligns with the native units in EnergyPlus and OpenStudio.
The OpenStudio Results measure does have an SI/IP switch for hits HTML report. With a single simulation you can run multiple instances of that reporting measure with a different unit preference to make both an SI and IP HTML report for a single simulation. Someone could make a single new reporting measure that generates multiple different outputs in different units that could be HTML, CSV, JSON, or some other format, but I'm not aware of any existing examples of that. If you have a custom post-processing working you could definitely write a measure to feed data into that exactly in the format you want.
