I suggest that you split the geometry horizontally by floor, or perhaps in finer granularity, and consider using the ZoneCrossMixing object to capture the stack effect. There is a "Delta Temperature" option that is applicable in this case.
http://bigladdersoftware.com/epx/docs/8-0/input-output-reference/page-018.html#zonecrossmixing
Mostapha,
Kyle
