The Severe Error appears to be unrelated to the location or weather file. The source of the error seems to be from the Controller:WaterCoil (CAV_2_COOLC_CONTROLLER) Action field. Perhaps change this from Reverse to Normal?
Assuming all of your equipment is set to autosize, the only modifications you would need to make to simulate in a different location are the Site:Location and DesignDay objects. You may also want to adjust the Site:WaterMainsTemperature and Site:GroundTemperature objects if they exist in your IDF.
Assuming all of your equipment is set to autosize, the only modifications you would need to make to the IDF to simulate in a different location are the Site:Location and DesignDay objects. You may also want to adjust the Site:WaterMainsTemperature and Site:GroundTemperature objects if they exist in your IDF.
