There are two approaches for this. If both stories are the same height, you could draw both diagrams at proper z height (working in 3d view so you can see them both. Then run create spaces from diagram once for a one story building and you will get two stories.
A cleaner and certainly more flexible approach is just to run spaces from diagram multiple times.
- Draw first floor diagram
- Run spaces from digram for desired number of stories (maybe hotel with two story podium with 20' ceilings).
- Draw tower diagram starting on top of podium.
- Run spaces from diagram again for the tower. You can use a different number of stories and floor to floor height and of course a unique digram than you used for the initial use of spaces from digram.
ceilings).ceilings. - Draw tower diagram starting on top of podium.
