Answering @Rwadhwa910's comment which is relevant in the broader context of the question since things have changed with libraries (basically they became so big that they got split in multiple files which are not loaded by default or it takes too long to load the OS App)
Library files are installed with your openstudioapplication version at /Resources/, (/usr/local/openstudioapplication-1.1.0/Resources on ubuntu, C:/openstudioapplication-1.1.0/Resources on windows, /Applications/openstudioapplication-1.1.0/Resources on mac). By default it loads the Resources/office_default.osm (which has the name implies relates an office building...) and Resources/hvac_library.osm (which has the components you see in the "Library" under the HVAC System / Thermal Zone tabs)
The midrise apartment are defined in various templates, such as the 90.1 and the canadian DEER ones:
$ cd /usr/local/openstudioapplication-1.1.0/Resources/ && grep -rli "Midrise" DEER_2017.osm DEER_2003.osm 90_1_2004.osm DEER_2007.osm DEER_Pre_1975.osm DEER_1996.osm DEER_2014.osm DOE_Ref_1980_2004.osm DEER_1985.osm 90_1_2013.osm 90_1_2010.osm DOE_Ref_Pre_1980.osm DEER_2011.osm DEER_2015.osm 90_1_2007.osm
So just load for eg the 90_1_2010.osm and you'll get the MidriseApartment space type. Go to "Preferences" > Change default libraries for eg:
Answering @Rwadhwa910's comment which is relevant in the broader context of the question since things have changed with libraries (basically they became so big that they got split in multiple files which are not loaded by default or it takes too long to load the OS App)question.
Answering @Rwadhwa910's comment which is relevant in the broader context of the question.
