Hi,
You have to add the folder path to the energyplus file. For doing so, you have to go to the "Python Plugin System" section of the idf file and add the folder path to the system. The name section should be "PythonPluginCustomSchedule" and the search path section should be: "C:\EnergyPlusV9-4-0\ExampleFiles"
Keep in mind that the search path should be the containing folder, not the python path!
See the attached photo:image description
Hope it works!
