Cause
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the Design Maximum Continuous Input Power field is actually setting the Simple Fixed Efficiency field and using the same variable optD.
https://github.com/NREL/OpenStudio/blob/develop/src/energyplus/ForwardTranslator/ForwardTranslateElectricLoadCenterStorageConverter.cpp#L75-L85
// SimpleFixedEfficiency, optD
optD = modelObject.simpleFixedEfficiency();
if (optD) {
idfObject.setDouble(ElectricLoadCenter_Storage_ConverterFields::SimpleFixedEfficiency, *optD);
// designMaximumContinuousInputPower, optD
optD = modelObject.designMaximumContinuousInputPower();
if (optD) {
I opened an issue in the OpenStudio SDK repo here.
https://github.com/NREL/OpenStudio/issues/4174
Solution
As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio, which would look something like this.
# get all objects
electric_load_center_storage_converters = workspace.getObjectsByType('ElectricLoadCenter:Storage:Converter'.to_IddObjectType)
# OR
# get one object, e.g. if there's only one in the model
electric_load_center_storage_converter = workspace.getObjectsByType('ElectricLoadCenter:Storage:Converter'.to_IddObjectType).first
# set Simple Fixed Efficiency field to 0 rather than what's entered in the Design Maximum Continuous Input Power field
electric_load_center_storage_converter.setDouble(3, 0)
Cause
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the Design Maximum Continuous Input Power field is actually setting the Simple Fixed Efficiency field and using the same variable optD. Feel free to open an issue in the OpenStudio repo.
https://github.com/NREL/OpenStudio/blob/develop/src/energyplus/ForwardTranslator/ForwardTranslateElectricLoadCenterStorageConverter.cpp#L75-L85https://github.com/NREL/OpenStudio/blame/1e4f9fda38c9a4917b3a4a196a6c9f80d469502c/src/energyplus/ForwardTranslator/ForwardTranslateElectricLoadCenterStorageConverter.cpp#L75-L85
if (optD) {
if (optD) {
Solution
# get all objects
# OR
Cause
if (optD) {
if (optD) {
Solution
# get all objects
# OR
design_maximum_continuous_input_power = electric_load_center_storage_converter.setDouble(3, 0)
Cause
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the Design _Design Maximum Continuous Input Power Power_ field is actually setting the Simple _Simple Fixed Efficiency Efficiency_ field and using the same variable optD. Feel free to open an issue in the OpenStudio repo.
if (optD) {
if (optD) {
Solution
# get all objects
# OR
Cause
Looks like a bug due to a copy/paste typo (see below) where the code to ForwardTranslate the _Design Maximum Continuous Input Power_ field is actually setting the _Simple Fixed Efficiency_ field and using the same variable optD.
Feel free to open an issue in the OpenStudio repo. As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio.
if (optD) {
if (optD) {
Solution
# get all objects
# OR
below). Feel free to open an issue in the OpenStudio repo. As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio.
if (optD) {
if (optD) {
Looks like a bug due to a typo (see below). here. Feel free to open an issue in the OpenStudio repo. As a workaround you could write a simple EnergyPlus measure to fix the IDF after it's been translated by OpenStudio.
if (optD) {
if (optD) {
