I've used SankeyMATIC for EnergyPlus' End Uses table. It's a quick way to get a diagram without using a data visualization library, e.g. D3.js or Python. I used a spreadsheet with the End Uses table pasted in to create the format required by SankeyMATIC.
I've used SankeyMATICSankeyMatic for EnergyPlus' End Uses table. It's a quick way to get a diagram without using a data visualization library, e.g. D3.js or Python. I used a spreadsheet with the End Uses table pasted in to create the format required by SankeyMATIC.SankeyMatic.
