What version of OpenStudio are you using? And can you please open up one of the .idf files produce by the simulation and copy the text of one of the ZoneVentilation:WindandStackOpenArea objects that is failing?
My guess is that you have special characters in the zone or schedule name that is causing your input fields to be misaligned. Notice how the fractional schedule field is showing up in the height difference, angle values showing up in the temperature field, etc. In general, it is best practice to use only the characters A-Z 0-9 and _ in zone and object names.
