The model you supplied has only an AirLoopHVAC, no radiant system.
The AirLoopHVAC is like in the picture you included: it has just an Heat Recovery Ventilator, two fans, and a SetpointManager:FollowOutdoorAirTemperature which for some reason is controlled to exactly follow the outdoor wet bulb temperature.
It isn't clear when you experienced the 10°C higher temperature as I see no graph in your original post, but if that's during a hot summer day, that is probably very much expected.
The model you supplied has have only an AirLoopHVAC, no radiant system.
