I assume you're referring to unit heaters? Yes, unit heaters can be modeled using the ZoneHVAC:UnitHeater object, which supports electric heating coils as well as water, furnace/fuel, and steam coil types.
I assume you're referring to unit heaters? Yes, unit heaters can be modeled using the ZoneHVAC:UnitHeater object, which supports electric heating coils as well as water, furnace/fuel, and steam coil types.object.
