I ended up answering my own "stupid" question here - just for people who might make the same mistake...
Make sure if you select "OtherSideCoefficients" in "Outside Boundary Condition" at BuildingSurface:Detailed inputs, especially when you edit your idf in a text editor. If, for instance, "Outside Boundary Condition" is set to "Outdoors" as we usually put for exterior surfaces, "Surface Other Side Coefficients Exterior Air Drybulb Temperature" outputs would show "0" than whatever you expected.
Sorry for this mistake-driven question here and thank you, unmethours! :)
