You may want to take a look at this PNNL report that characterizes the DX coil performance curves of this unit, including generic regression coefficients. To model it properly, it requires a Coil:Cooling:DX:MultiSpeed object, which can only be referenced by a AirLoopHVAC:UnitarySystem or AirLoopHVAC:UnitaryHeatPump:AirToAir:Multispeed object. I recommend going with an AirloopHVAC:UnitarySystem object, as it is intended to replace all other air loop equipment. The UnitarySystem is unique in that it can accommodate all fan and coil types whereas other system types are specific to the type of fan and coil available for simulation.
