It looks like all of the Schedule:File objects are referencing the same Incas.txt file that contains the schedule data because that is what is set for the File Name input field. Without any "/" in the File Name input field , this Incas.txt file needs to be saved in the same folder as the IDF in order for EnergyPlus to read it. If that doesn't work, then try entering the full directory path to Incas.txt instead.
I haven't used the FMU/FMI features of EnergyPlus, so I'm not sure how this relates to the FMU's resources that you mentioned.
