Here's a partial Radiance scene description for a swimming pool that uses the 'dielectric' primitive:
# pool.rad
void plastic white_paint
# pool water
void texfunc wavy
6 wave_x wave_y wave_z wave.cal -s .25
wavy dielectric wavy_water
5 .9 .9 .91 1.33 0
# wavy glass wavy_water
# 0
# 0
# 4 .9 .9 .91 1.33
# genbox white_paint pool 3 5 1
[etc...]
(source: http://radsite.lbl.gov/radiance/digests_html/v2n6.html)
This suggests that the RGB transmittance of water is ~90%, which is a good starting point. Next, you're modeling as "glass" instead of "water" (or in Radiance parlance: "dielectric"), so you need to add a factor for the water depth and turbidity, among other things. This is where it gets messy, but some interesting references I saw are this and that.
Good luck/have fun! - Rob
# pool.rad
# pool water
void texfunc wavy
5 .9 .9 .91 1.33 0
# 0
# 0
# 4 .9 .9 .91 1.33
[etc...]
This suggests that the RGB transmittance of water is ~90%, which is a good starting point. Next, you're modeling as "glass" instead of "water" (or in Radiance parlance: "dielectric"), so you need to add a factor for the water depth and turbidity, among other things. This is where it gets messy, but some interesting references I saw are this and that.are:
http://pdf.aminer.org/000/540/062/rendering_natural_waters.pdf
http://en.wikipedia.org/wiki/Rendering_equation
Good luck/have fun! luck! - Rob
