If you intend to extract results from E+ tabular reports in CSV format (eplustbl.csv), you should first make sure that the output is requested in your model, by adding the following lines:
OutputControl:Table:Style,
CommaAndHTML; !- Column Separator
It is easier to do in jEPlus v2.1 rather than v1.7. Here is the manual: https://www.jeplus.org/wiki/doku.php?id=docs:jeplus:v21:rvx#csvs_-_e_tabular_report
And here the video showing the process: https://youtu.be/HkGXophS_kg
