I ended up using a ZoneCrossMixing object so there was energy flow between the zones and a Material:NoMass object with the bare minimum Thermal Resistance [m2-K/W] = 0.001000 + 0.0001 just to be safe. I couldn't use a metal sheet because I am also modeling PCM in the IDF, but this seems to work just as well. The temperature on either side of my surface to put the light tube diffusers in should have the same temperature on either side anyway from the ZoneCrossMixing object.
