Reading the log you included the workflow can’t find OpenStudio Results. Assuming you are using the OpenStudio Application it makes a directory next to yourmodel.osm named yourmodel. Inside that among other tings are a copy of the measured used. Have you deleted some of those files or moved your OSM file elsewhere eon your computer. You could try deleting, and the re-adding the measure to pull it back in.
I also see it you are using a 2.x version of OpenStudio instead of 3.x. It is possible that somehow a newer version of the measure got into the project, although there are checks against that. It is possible that could look similar to this that instead of reporting that the measure can’t be opened, it could look like it can’t be found.
