The heat recovery function of ChillerElectricEIR is not supported by OpenStudio. You could write an IDF Measure to make the necessary changes to the idf file produced by OpenStudio.
The more technical answer is that ChillerElectricEIR is a WaterToWaterComponent in OpenStudio that is designed to communicate between a chilled water system, and optionally a condenser system, but not a third heat recovery system.
