Sounds like you might be experiencing the same problem reported in these issues. Basically, running an OpenStudio simulation with EnergyPlus v8.2.0 causes an incorrect results summary. The workaround is to remove EnergyPlus v8.2.0, install EnergyPlus v8.2.0-Update-1, and run 'scan for tools' from OpenStudio -> Preferences.
