You need to pass the state manager
import sys
from pyenergyplus.api import EnergyPlusAPI
def dummy_callback_function(state_argument):
print("My argument is called state_argument to avoid duplicating the outer variable below called state")
api = EnergyPlusAPI()
state = api.state_manager.new_state()
api.runtime.callback_begin_new_environment(state, dummy_callback_function)
api.runtime.run_energyplus(state,
'-d','C:/Users/Sajit/OneDrive/Documents/EnergyPlusExamplesForFMU/DirectPy',
'-w', 'C:/EnergyPlusV9-4-0/WeatherData/USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw',
'C:/Users/Sajit/OneDrive/Documents/EnergyPlusExamplesForFMU/EX1_9_4/TEST_NF_VFMU.idf'
# If you need to call run_energyplus again, then reset the state first
api.state_manager.reset_state(state)
import sys
