Can you indicate what error you are seeing when trying to launch the OpenStudio App?
A diagonal line on a surface tends to indicate that the surface isn't planar - one of the vertices is not in line with the other three. Take a closer look at your model by opening it in a text editor and inspecting the vertices for the surface with the diagonal line. See if they all lie on the same plane.
In sketchup, have you set the view to boundary surface type and looked through the model on each axis (x,y,x) with the cross-sectional viewer tool? That will help identify remaining surface matching errors. Just because the surface matching script runs does not mean the model is surface matched - if two surfaces don't share vertices, they won't match.
You can also use the model inspector tool to see if there are orphaned surfaces or spaces.
If using sketchup, I recommend using the plugin with an older version of openstudio, and saving it in the older format, and then updating the model version by opening it with the 3.0.1 app version. Sketchup is not supported for use with OpenStudio v3.0+. Floorspace.js is the preferred approach for OpenStudio v3.0+ models.
