Here is an example that exports schedules to CSV file. You could adapt that to export constructions, surfaces, or any object you want. While this is making a report, if you don't need the SQL simulation results you can make it a model measure which can be used with Apply Measures now.
As a second example here is a SketchUp Plugin user script that writes a CSV with high level space and space type information.
