If it is essentially just a fan and a heating coil, then you should use the ZoneHVAC:UnitHeater object in EnergyPlus. This object is an example of a compact object -- one object in the IDF that is built from multiple other objects (fan and heating coil, in this case) also in the IDF that it needs to reference.
