The answer to your question is that you can choose one of the single-zone systems with a type of DX cooling.
PTAC is probably the best match...take a look at that system description in the documentation and see if it matches up with what you have.
*I'll edit mine too then :)
The answer to your question request is that you can choose one of the single-zone systems with a type of DX cooling.
