Great job on thinking about looking at the openstudio-standards
gems for reference. However, the method in the gem will not help you because it is meant for SiteGroundTemperatureBuildingSurface
(reference).
Which version of OpenStudio are you using? OpenStudio has bindings for the object SiteGroundTemperatureFCfactorMethod
as of 3.0.1.
If for some reason you really cannot update your model to 3.0.1, you will need to create an EnergyPlus measure to get the translated Site:GroundTemperature:FCfactorMethod
and change the values. For simplicity, I would recommend just updating to 3.0.1.
(reference).
Which version of OpenStudio are you using? OpenStudio has bindings a binding for the object SiteGroundTemperatureFCfactorMethod
as of 3.0.1.
